Lian li a70fb and psu cable lengths
Caporegime
14 Dec 2005
armoy, n. ireland
Got one of theese coming tomorrow and im wondering if the cables on my psu will be long enough. Main concern is the 8 pin atx and wether or not ill need an extension for this as this case has a bottom mounting for the psu. My psu is a thermaltake toughpower 750w. From a few pics ive seen the 24 pin atx connector should be fine.
if your lucky you might be able to feed it through the cpu socket cut out and under the mobo then feed it over the top failing that what i normaly do is run it up the pci back plates and under the gpu round the vrm heatsinks and on there maybe that will work for you does on my p6t7ws
Thanks for that mate. Another quick qwery, is there much space between the underside of the mobo tray and the side panel, hoping to be able to hide a few cables below the mobo tray to keep things a bit neater.
