It will fit at the bottom, if you're comfortable with the pump being above rad.
Doesnt seem ideal with GPU above using an AIO anway
I am taking AIO. looking at De8our vid the mobo can be moved up and down on the tray
however having 2nd thoughts about getting this case
Looks rather nice, how much space difference was the sfx-lti Vs standard SFX PSU? Were the cables a bit cramped to fit?
Has anyone got an update on when these cases will be available in the uk? Had one on pre order from OC since they been released to buy. Patiently waiting for this case as its the last thing i need for my new 3080 build!
Their first batch must have gone out, so next one is due in a month.So ETA Changed again, now 10th Feb
Hi guys, ended up here after doing some research into the Corsair SF750 and whether the cables were sufficiently long enough to pair with an ATX board in the O11 Mini. Has anyone been able to test this yet and know if extensions are required? Pre-orders just keep getting put back it seems.
Thanks!I’ll let you know soon as I have same PSU and wondering the same.
I want to order some custom cables so want to check length anyway
