Lian Li O11D- Mini....(latest post with AIO Up top in ATX format)
fot those of you have have received your mini so far, do you mind telling me the distance between the motherboard standoff to the side panel please?
I'm sure it will fit but hard looking at it from a video perspective whether an Alphacool GPU block will fit since the 6800xt are around 14cm in width whereas the nvidia (not sure about 30 series) are 11-12cm width.
I haven't seen a single video with a AMD card and mini yet... all of the one's i've seen are 3080s
p.s. Alphacool GPU block is L x W x B: 142,5 x 260 x 24,5 mm
Ordered AM 23rd November - looks like I missed the cut this time. Hoping for 10th of Feb drop now . . . . EDIT : Just got shipping notice :) hurrah ! Working on a Sunday - thank you OC.
Edit - i have removed my previous rant, as I think it was a little petty of me.
My main point still stands that it would make sense for them to update us a bit more on the pre-order. The date changed 3 or 4 times, and the only reason I found out what was going on is by contacting them pro-actively. It just seems reasonable to expect some open communication.
What's the situation on the Mini currently? I ordered a white version on 30 December. When am I likely to receive?
Also I wanted to add LED lights like in the Razer Dynamic. Any advice as to what strips I should use? (should also be able to sync up with my other lighting..)
Does the GPU length interfere with the pump/res if it's not verticaly mounted?
its interfering more now with it vertically mounted than it did when it was sitting flat, but thats just because im not using the official vertical mount for it, its kind out about 1 to 1.5cm inside the case further than it needs to be with the mount im using now, it will be better when they release the proper vertical back panel, but even with it in the case normally, theres barely any room, its very tight, now imagine that GPU 1-1.5cm closer to the back of the case, its still going to be pretty much butt up against the pump, and the pump cant go any further towards the front of the case, I had to move it back a couple of mm as it was because it was vibrating on the front glass panel, making a hell of a noise, it was a difficult build thats for sure.
The mount im using for now I got from the rainforest, its the EZDIY-FAB Vertical Graphics Card Holder, you'll see how it pushes the GPU a little further back into the case itself, but I went for this one, because all the other mounts screw in from the other side which put the GPU closer to the motherboard, infact, pretty much right up against the motherboard, I wanted the GPU closer to the glass panel to make sure I could clear the pump, and this mount was universal, either up against the motherboard or closer to the glass.
I said in the other thread, anyone whos thinking of modding the case to get an ATX PSU in, you've not got a chance, not unless you plan on cutting a big hole in the side panel, and then you'd still only be able to mount an ATX PSU using 2 screws leaving the other side hanging out of the case, SFX-L only just fits.
All the supplied pump mounts are for a DDC pump, so I had to mod one of the mounts to get my D5 NEXT pump on it.
And on a final note, make sure you fit your coolers to your motherboard before installing your board in this case, the cut out at the back doesnt line up with the backplate for my cooler.
I'd also like to know which parts to order to light up the bottom and inside like in the Razer edition.
Also waiting on a white one ordered 28th of December. Been coming here for updates.
Hoping we get some shipping confirmation soon and dont have to wait until February..
