1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Lian Li O11D- Mini....
Discussion in 'Case Central' started by orbitalwalsh, Jan 7, 2020.
  1. bakes0310
    Capodecina
    Not doubting you but why are SFX powersupplys any good. I always buy high quality PSUs and I've never bought a SFX one before. The best I've seen on this store is the Corsair titanium 750w.
  2. Legend
    What do you mean "why"? Check out the reviews of the SF600 Platinum... it's a top quality across PSU the board and more than what most people need. I'm running one with a 2080Ti, 3600X, 32GB RAM and it's MORE than enough. There's also the SF750 for those who might need the extra juice.
  3. bakes0310
    Capodecina
    650w powering your pc, fair play didn't realise you can get away with something so low.
  4. Legend
    Yes, really no problems whatsoever, and I've seen plenty others doing the same. Power draw is massively exaggerated... it comes down to the PSU quality more than anything else. The fan on mine barely ever spins up either (a bonus over the Gold), so it's super silent. Great little unit, it really is.
  5. bakes0310
    Capodecina
    Thanks legend, my current PSU is way overkill then at 1000w PSU platinum. Next one won't be any higher than 750w, that's gonna save a few pennies to go to rest of build.
    Going back to this case, it looks great and I can't wait to see some pictures of people's builds.
  6. satchef1
    Mobster
    You might exceed 600W with a Threadripper and a Radeon VII. With other single-GPU set-ups? Not likely. Your sig rig is likely pulling in the 300W-350W region. Possibly 350W-400W depending on other components and your GPU clocks.
    High capacity SFX power supplies are a fairly new thing. Wasn't that long ago the SFF community consisted of people trying to underclock their hardware to get it to run on a weedy 250W PSU. There were fires :D Now there's SFX PSUs up to (IIRC) 800W, and even a 400W NanoATX supply. So pretty much anything (apart from some SLI/Crossfire set-ups) goes.
  7. Mr Gimp
    Mobster
    I've been running a 750 Platinum in a Louqe Ghost S1 with a 9700k and 2080Ti FE since May and the PSU is utterly silent for the majority of the time. The fan barely needs to spin up. They're seriously amazing little bits of kit these SFX PSUs.
    Love this case. I'd dearly love to do a water build in one but spent enough already :cool:
  8. bakes0310
    Capodecina
    Thanks chaps, I've clearly been overestimating due to poor knowledge on what I require to power my system.
  9. satchef1
    Mobster
    Most in-depth look yet:
    Drive support: 2x 3.5" drives + 2x 2.5" drives in the rear chamber. 3x 2.5" drives in the main chamber (takes the space of the bottom radiator).
    Tentative release date of April/May.
    Would be great to know the dimensions. Best guess I can come up with is 380x250x400mm (HWD).
  10. Grim5
    Wise Guy
    sexy case
  11. PinkFloyd
    Capodecina
    Nice looking case that, if I decide I want to go watercooled rather than compact next time I rebuild my rig this is right at the top of the shortlist!
