OcUK Staff
- 26 Nov 2014
- Stoke
That'll be the new guy @[OcUK]PREDATOR for those, but the forum won't let me tag him
@orbitalwalsh May I ask did you get the PC-O11 Air Filter Kit from Demci? And they are perfect fit with the PC-O11 Dynamics?
Thanks for the heads up!Yep, but postage then vat and FedEx charge (if you can't get it off) adds up a cheap product .
And they fit fine , only thing the air has over the Dynamic is extra 3 fans at the front
I am shipping it outside EU first so there will be no VAT and Fedex chargers, some more I have spotted a pricing error and they have offered me a 10% off code. *LUCKY*![]()
I have them, and GPU temps are few degrees lower@orbitalwalsh Question: Are the 3 bottom fans needed if you use the vertical mounting kit for the gpu?
Excellent looking build, I'm guessing the vertical GPU mount blocks off access to the other PCIE ports on the mobo? I'd be tempted to try one if it wasn't for my need of a soundcard!
Am I right in thinking there is a Lian Li Vertical adapter, but also a Coolermaster or a Phantex one that would fit in the 011-D?
Yeah, if like me your using a non reference wider PCB card and tall ram then Go for Phanteks , if not Cooler master is the one I've got
The Lian-Li option no good?
I think the Lian-Li will only work if you are planning on having nothing below the GPU as it mounts to the bottom of the case as well as the back.
Does anyone know if the Cable Mod version is any good? People seem to rave about it...
