Lian-Li PC-V600 CPU Cooler
should do if the height is under 78mm (although dont forget about air flow) as thats the height of a silverstone nt06 lite (using psu fan) and that can definately fit :)
Actually it's 67mm high. It will fit.
The CNPS 7000, 7500, 8000, and 7700 should all fit height-wise. However, the 7700 (possibly thr 7500) may be too wide - that would depend on the position of the CPU socket on the motherboard. :)
nope doesnt fit, got the psu now sitting on top with the side panel off untill tuesday wen a CNPS 8000 arrives. fan mod is in order
That's very odd. It's definitely 67mm in height, I just double-checked the Zalman website. However, it must be taller than the 7000 and 7700. :confused:
It always pays to measure first I spose....
I'd recommend a Silverstone NT06 Lite over the CNPS 8000, unless you've already ordered one...
i just cant get the power suppy to fit. it wont sit in its place because of the heat sink.
ill try and grab some pics *** tonight
