Lian Li pc70 fan filter
17 Apr 2007
My lian li pc70 front twin fan filter is getting old now and needs replacing, can anyone think of something to replace it with. I did try and clean with some water but its dropping to bits.
Can't seem to find anyone that sells the spares :(
19 Oct 2002
The land of Cows n Grass!
I have the same problem :(
The only thing that I have ever managed to find that is even remotely close is the something that fits into our old vax wet & dry vacuum cleaner. There is a small filter that sits on the outside which is made of material that is just like the old lian-li stuff.
I dont know where to get it in larger sheets tho, if I could then it would solve the problem.
