Lian Li V1000 Rear Fan.
20 May 2006
I've just noticed the rear fan on my case is bringing air into the case rather than taking it out, would it be better cooling to leave it bringing air into the case?
Or should I turn it round?
Thanks
8 Jan 2007
London & Dubai
The Lian Li V1000 works on pressure. Air enters the case via the 2 fans & exits via all the holes in the case.
But it would also depend on what type of CPU cooler you use, In some cases it would be better to have the fan blow out, i.e. If you have a Tuniq Tower or somin installed.
OP
20 May 2006
kool thanks mate, i thought it would work that way but double checked just incase :p
The CPU is on water.
