i had this setup but i used the 8cm fan that came with the ninja aswell as the 120mm fans in the case, its one of the best coolers you can get for this case(got one going psare hint hint )
I swapped the 120mm case fans for Noctuas but kept the stock fan with the Ninja.
I could get my E8400 to stable at 4GHz but I was more than happy with 3.6GHz - it's plenty fast enough and the Ninja keeps the whole setup lovely and cool.
In terms of cooling vs size, you can't get better than the V350 with a Mini Ninja.
Yeah I already have the case sitting in my room, just need to know if I need to order replacement fans or not, although I'm tempted I will wait and see when i power it on
