- 5 Jan 2010
- London
Hey again
I'm using XP + Logitech Z-5500 + Xonar D1 sound card
Iv'e got several questions to put forward:
-What sample rate should i use on the Audio Centre for the D1?
(I know it's been posted but didn't understand it)
-What EQ should i use? The best one is Soft rock, i gave up on the lack of bass on it, so made one my self by trial and experimenting. Should i have EQ on at all, especially seeing as i have the Z-5500? It does sound better with my "setup" though
-Do any of you guys use the dolby options? As i don't No need to IMO...
-What should i set on the effect for the Z-5500? 6 ch direct or Dolby Music? The Dolby Music sounds a lil better, just not sure what is better.
-Flexbass: Any use? As i can't hear a difference with it on(with large speakers enabled) or off.
-GX MODE? I don't game on the PC. Is there any use in this feature being enabled?
-SVN: Any use at all? Just seems to up the volume on everything.
I know i'm a noob at this subject, but i really do love my music....and the D1 hasn't really delivered to my high expectations....£60...and can't really hear a huge amount of difference between my gd old realtek on-board...
Thx in advance for the repplies!!!
