Looking for a 120mm CPU fan with 4-pin PWM
FYI :D
lol nice :)
Anyway i think im set on a Corsair Air Series SP120 Quiet Edition High Static Pressure.
Just worried it'll be so good i end up replacing my 6 case fans with Corsairs. Damn that'll cost me.
Hi setter.. that would look pretty good in my case with the blue colour matching my board,do u know the fan speed rpm when its idle?
In bios it shows at 415 rpm, im gonna remove it from the PWM splitter and put both fans onto the motherboards cpu fan headers, (alpenfohn k2 cooler). Should hopefully then display speeds in ai suite or hw monitor.
You wouldn't want all of your fans to be the SP120's surely, you would want airflow fans where they have less restriction. :) Static pressure are for rads/heatsinks/hard drive cages. Just something to keep in mind. They all look the same when running.
