looking for headphones for outdoor use
woah? £120-£150? 0.0!?!?!
i nevr thought it would be 'that' much =/
i was expecting somthing like ....around £60? 0.0'
so basically ..which ones can i get..including the ones stated here?
Mate you can get headphones that cost hundreds or even thousands!!
It all depends, what type of music will you be listening to, open or closed? Basshead or not? Many factors involved in choosing the right headphones.
The M50s I believe have gone up in price there's been a hike in demand for them.
For your budget you may consider:
PX100 or PX200 from Senns, or Senns HD238/338s,
Sony XB 500 for Bass,
AKG K450 good for Pop, Hip Hop, Rock type music and portable,
ATH ES55, sister to the ES7,
Grado SR60i,
Those are just a few to name, there are plenty more....
Grado SR60i,
lol...tbh..i like none of thoughs =/
my friend has got the sonys u suggested, so dont think il want the same thing. =/
i listen to ..r&b, hip hop, music with bass (if thats what u meant by basshead)
open or closed? dont mind i think. depends if it makes any diffference..
hhmm...i guess i should start low... and try out the Arctic Sound P281 Professional headphones like valkia suggested?
since that one does look alright...although...seems a lot like a gaming headset xD
so...hows my choice? bad decision? lol
Check out Head-Fi forums, loads and loads of posts with similar requirements to yours, and loads of reviews of various headphones to match budgets of all sizes!
