Looking for Ultra Wide 144hz around 34" best options?
3 Jul 2010
I have a old Asus VG278H 27" TRUE 120Hz 3D Widescreen LED Monitor with NVIDIA 3D Vision
Its been pretty decent but doesn't have Display port (using dual dvi-D) , is only 1080p plus I've been tempted to to switch to a Ultra wide set up.
I have a 1080ti and 2700X currently but will be looking to do full upgrade in future, 3080 etc...
My budget is around £500.
Looking for Ultra wide 1440p (Guessing 3440x1440 is sweet point)
around 34" 144hz freesync and gsync compatible. Prefer Non curved but slight curve ok if only option.
Using it for Gaming, media and web browsing.
The below model seems to tick most boxes for me.
G-MASTER GB3461WQSU-B1
Yeah thats the only one i found also. I will look at Curved ones as well, especially if performance is better for same or less money.
Performance will be the same, but for more money and no IPS unless you spend a lot more.
VA curved is your best best if you don't want flat.
