Apparently 10,000 people do 1,2,3,4,5,6 every week, so even if they did come up you would win very little.
wow interesting thread about it all
1 in 14 million DAMN!!
Hands up all you ocukers that have a direct debit setup to do the lottery twice a week.... u know who u are lol
Relatively easy way to get your head around it is to remove all association between them, replace the numbers with 49 distinct symbols. Easier to see then that any combination of 6 is equally likely.I dont get this atall, I was never good with this sort of thing. But surely the odds of numbers being in sequence are slimmer than the odds the numbers will not. And surely that would make a difference to the statistics overall
I've known that since the lottery started.Relatively easy way to get your head around it is to remove all association between them, replace the numbers with 49 distinct symbols. Easier to see then that any combination of 6 is equally likely.
In theory, each number has an equal chance of being picked,
Although odds of winning with any set of 6 numbers are the same, sets of numbers that might be chosen by disproportionately large numbers of people (such as 1,2,3,4,5,6) should be avoided as the prize will be split equally among all winners.
Yes.
Given that there are multiple sets of balls and multiple machines, both of which are subject to rigorous inspection, I doubt there is any serious risk of any one ball being more or less likely to come up. If you could prove this, you'd as good as shut down the lottery overnight as the gaming license folk would come down on them like a ton of bricks.
Well it could take very much longer than 14 million tries. There is a 1 in 14 million chance (for example) every time you make a draw. It doesn't mean that after 14 million tries you will see your numbers come out.
Don't the Mafia but all the combinations of lottery tickets on certain rollovers? Or is that an urban myth
The lottery has had MANY draws, yet the stats for each number and how often they have come up are not the same ... which seems to indicate that there may be an inherent bias in the process (as you would expect the stats to tend towards being the same after so many draws)
Still not a good idea to play them for real as when you win you'll be sharing your prize with probably hundreds of other people who did the same thing
Guilty as charged, same 6 numbers Wed and Sat for many a year by DD...![]()
depends on how the balls were loaded, is it always in the same order? and how they are spun.
