Man of Honour
I'm looking for a quiet low budget build, but one area I'm willing to spend a bit more on is the CPU cooler. I'm currently thinking of a Thermalright True Spirit 140 Power, which my initial reading indicates gives a very good combination of performance, noise and price (even in the UK, where it's 60% more expensive than the manufacturer's recommended price in the EU - 60%!). The main drawback is that it's 172mm high.
That's not going to fit in most of the cheap cases I'm looking at. I have found one that it should fit in - Kolink Pitch is stated to have 174mm clearance for CPU cooler. It's not the case I really wanted (too many fan holes to let noise out and a top fan hole makes me worried about spilled drinks), but it's the only cheap case I can see that CPU will fit in (and it also has ample clearance for longer graphics cards) and it is very cheap.
I can't find any reviews for it...and it is very cheap. That makes me wary. I hardly care at all about appearance, so that's not an issue. If anything, I'd probably prefer a plain beige box for nostalgia reasons
So...does anyone have one? Is it OK? Or does it amplify every sound and hurl it out of the hole in the top to assault your ears before falling apart in a few weeks?
Or does anyone have any suggestions for alternatives for the case and/or CPU cooler? I'm after as quiet as I can get on the cheap and I think I'd be better cutting cost on the case than on the cooler (but I'm willing to listen if I'm wrong about that).
