m-audio problem
Permabanned
19 Oct 2007
basically got my audiophile 192 all up and working both in DS and asio in foobar2k.
Also works playing music in windows media player.
However
if i try and stream video, be it using "adobe flash player" or windows media player embedded in sites, i get 5 seconds of footage and then it pauses, and no audio at all. it will only play again if i select somewhere on the navigation bar to fast forward or reverse, where it will play 5 seconds more and pause, no audio.
in flash player, i can get it to work fine but only when im on the MICROPHONE settings :whatever: menu within the applet. when i close this it pauses and theres no audio.
I know its related as it worked fine before with an audigy 1.
Im using spdif if that helps.
thanks! Help!
Very weird problem there. I would re-install the drivers and see how it goes. Maybe you changed something by mistake in the drivers section, that only thing i can think off.
