Depending on access issues and funding, sounds like a digger of some sort would be useful. Scoop up the weeds and gravel into a skip and pull the tree stump out.
check got that, got most gardening hand tools just lacking the real man tools, checked out the price of them and wondered where it became more cost effective to actually own the tool rather than renting![]()
Stump grinders are really nasty fcukers. I would only use one as a last resort.
Do you specifically need anything where the old trees are? If not dig down 2 feet or so and chop/saw off trunk about a foot underground then cover it up.
Stump grinder will pretty much only take you to surface level with ground, trying to use one over a partly dug pit round a stump really really scares me.
Best bet is pulling them out if you can, but cutting them off well below surface normally means you wont see them again![]()
Do you need the tree to go ASAP? Could you not just cut a ring of bark out of it and let it die slowly?
funding isnt really an issue, I could just pay someone to do it for me but the thought of wielding man tools arouses me, got some mates coming over to help me too so that warrants a BBQ, which is about as manly as you can get!
get yourself a JCB / excavator
testosterone ahoy !
not sure if one would fit down the side of the house, I don't want one of those puny ones, would have to be a big mumma JCB otherwise I'd feel mildly homo.
