Max amount of ram,speed i3 14 gen + z690 mb
super dissapointed that a 13600kf need so high increase of pl1 and pl2 not to edp throttle 255 and 275 watt, icc max 245-250
does anybody know if a 14400f edp thottles ?
in games never chip will ever have a problem with power limits
the limit only kicks in under high stress loads
in game my CPU pulls a max of about 150w so no wear near the limits
i had a 13500 that would pull about 60w on average so i would assume the 14400 to be about the same
Shouldn't a cpu run 100% fine, stable with no throttling what so ever ?
no there is no CPU that will not throttle under a max load(Gaming is not max load in any way)
thats what temp and power limits are there for that is the limit of the CPU
in general there not made to be run at max limits, if you CPU is pinned at max load you got the wrong CPU.
that why there is 128core CPU's out there
stock cpu
my 14100f runs at stock with no edp other,thermal throttling what so ever
Why do you care? Do you do anything that runs at max load?
The 14400F is slower in games, so why would you switch just because it doesn't throttle?
There's no need to worry about that.
