Max length of LAN cables ? or help with antennae
20 Oct 2008
Cornwall
Just how long can a LAN cable be ?
I am struggling with my network and either need to run 100m of LAN cat5 exterior or get some directional antennae, of which I know nothing.
Having just tried the 100m or LAN, I get nothing, so guess I need 2 antennae and what else ?
Anyone able to offer any assistance - this thread may help explain further my problems..
http://forums.overclockers.co.uk/showthread.php?t=18046135
Cheers all !
Can you tell me more - where can I get repeaters, and do they need mains power ?
Can I not run some sort of antennae, as I have a clear line of sight ?
Cheers for the help - this has done my head today..
Please explain more about switches - what sort of switch - I do have power half way up the mountain, but know nothing about switches - do OcUK sell them, and of so, what is it I am looking for ?
Thanks for the link K.C. - am off to take a look now !
Liquidfox - you say that 75m is about the right distance - is that pretty fixed, or might it be extendable...?
Either way, that seems like pretty good news to me, so I'll give it a try I think - Many thanks !
You can put the hub anywhere up to the 93m mark, although i'd recommend doing it before then to reduce risk of interference.
A hub/switch boosts the signal back to maximum, so in theory you could have 90m of cable, then a hub/switch, then another 90m of cable
Cool - what about having 2 hubs, if my run is over 180m - it is roughly 200m, but that is pretty much a quess - so 1 at 70m, another at 140m - would that also be possible ?
This help really is much appreciated !
yes, that would be fine, if you've got power at both those points.
Have you tried taking all the equipment and a laptop up to the antenna to test whether shortening the cable length will actually work?
I will say at this point to clarify, switches and hubs are almost interchangable terms. They do the same job, these days hubs are almost unknow, you will be buying a switch.
hubs and switches arnt the same :/ a hub is a multiport repeater that will send the same stuff down every channel where a switch only sends the packets down the intended route :/
So, it looks like I'll be ordering a hub or switch, maybe two then - Thanks all for the help !
Zarf - as for taking the laptop and all the stuff up the mountain - no, i haven't, as it has been pouring for days - we have no road to the house left, retaining walls to little fields that have survived for a hundred years have collapsed - A good idea, but maybe one for a sunny day..!
