Hi all
I'm going to upgrade to a meshify C case and want to check your views on general fan layout and also compatibility.
I'm planning a fractal design 360mm rad at the front, which I know from the spec fits. The top two and rear fans will be exhaust, but I already have some beastly scythe ultra kaze 3000rpm fans that I want to use. They are 38mm deep, do you think they will fit? Manufacture spec doesn't make it clear.
Alternatively I can use these fans in pull configuration with the rad, and use the original rad fans to exhaust.
Amy advice appreciated, haven't done this for a while! Cheers
Michael
Michael
