** MINE: THREE GREAT MONITOR DEALS!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Three great monitor deals here:
LG Flatron 34UM95-P 34" WideScreen Super-Wide LED Monitor @ £689.99 inc VAT
The UltraWide 21:9 aspect ratio makes movies and games more immersive than ever. Need to get some work done, too? All of that UltraWide real estate makes it easy to view multiple documents at the same time, so you don't need to flip back and forth between them.
The 3440X1440 UltraWide QHD display offers amazingly sharp picture quality. Its pixel area is about 1.8 times larger than an UltraWide Full HD 21:9 monitor, and about 2.4 times larger than a Full HD 16:9 monitor. It provides an efficient environment in using Microsoft Office programs showing 47 columns and 63 rows in excel.
sRGB is the standard color space of ideal color reproduction. So, with over 99% coverage of the sRGB spectrum, this LG monitor is a great solution for professional photographers, graphic designers or anyone looking for highly accurate color.
Multitasking doesn't have to mean shuffling back and forth between windows*. With a single click, the 4-Screen Split feature divides the screen into as many as four customizable segments, two-by-two. Now you can see four different windows at the same time.
The Dual Linkup feature allows two compatible portable devices--such as a computer, camera, phone, or Blu-ray player--to be connected to the monitor, and both can be viewed on the same screen simultaneously.
This monitor's Thunderbolt input/output port allows you to connect up to six compatible devices, moving data between them with incredible speed. The two channels of 10-gigabits-per-second throughput in both directions are up to 20X faster than USB 2.0. Thunderbolt is an exciting innovation for both expansion and premium video display.
The DisplayPort digital video interface is used to connect a high-performance video source to a high-resolution monitor. Thanks to its sophisticated design, a DisplayPort cable can also be used to carry audio, USB signals and other data as well.
LG’s LED backlighting delivers exceptional brightness and amazing image clarity. You'll see richer colors and deeper blacks too, and LEDs offer greater energy efficiency compared to conventional LCD monitors.
IPS (In-Plane Switching) technology enhances thA dynamic contrast ratio of 5,000,000:1 is your assurance of strong video performance, with deep blacks, bright whites and pleasing colors.e performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can now view the screen at virtually any angle.
Looking for the ultimate in fine-tuning for your LG monitor? This model is designed to work with compatible calibration devices* that take specific readings and guide you through precise adjustments of color, brightness and more.
Specification:-
- Screen Size Class (diagonal): 34"
- Panel Type: IPS
- Aspect Ratio: 21:9
- Resolution: 3440x1440
- Color Gamut (CIE1931): sRGB 99%
- Brightness (typical): 320 cd/m2
- Contrast Ratio(Original): 1000:1
- Viewing Angle (CR>10): 178/178
- Colour Depth (Num of Colours): 1.07B (8-Bit+FRC)
- Pixel Pitch (mm): 0.2325
- Surface Treatment: Anti-Glare 3H
- Connectivity: 2x HDMI, 1x DisplayPort & 2x ThunderBolt
- Warranty: 2yr
Was [£759.99] Inc. VAT
Only £689.99 inc VAT.
ORDER NOW
Asus PG278Q ROG Swift 27" G-Sync 144Hz Gaming Widescreen LED Slim Bezel Monitor - Black/Red @ £629.99 inc VAT
Quite possibly the best gaming monitor ever made and ideally suited to NVIDIA cards with 3D Vision 2.0 and G-Sync technology. This monitor runs at a staggering 2560x1440 resolution with 144Hz technology and a 1ms response, even better this is the latest in TN technology.
The ROG SWIFT PG278Q represents the pinnacle of gaming displays, seamlessly combining the latest technologies and design touches that gamers demand.
This 27-inch WQHD 2560 × 1440 gaming monitor packs in nearly every feature a gamer could ask for. An incredible 144Hz refresh rate and a rapid response time of 1ms eliminate lag and motion blur, while an exclusive Turbo key allows you to select refresh rates of 60Hz, 120Hz or 144Hz with just one press. The ROG SWIFT contains integrated NVIDIA® G-SYNC™ technology to synchronize the display's refresh rate to the GPU. This technology eliminates screen tearing, while minimizing display stutter and input lag to give you the smoothest, fastest and most breathtaking gaming visuals imaginable. Connectivity is simple, yet robust, with a single DisplayPort 1.2 port to enable NVIDIA® G-SYNC™ and dual USB 3.0 ports for convenience.
Conventional 60Hz monitors show extensive motion blur which detracts from your gaming experience. The ROG SWIFT PG278Q Gaming Monitor with NVIDIA® Ultra Low Motion Blur technology* reduces the effects of motion blur by delivering crisp edges in fast-paced gaming environments for perceivable differences in natural movement.
ASUS-exclusive GamePlus Technology enhances your gaming experience further by providing you with crosshair overlays for FPS games and multiple in-game timers for RTS/MOBA games.
The ROG Swift has a super-narrow 6mm bezel that begs this monitor to be used in multi-display gaming set-ups. With VESA wall mount capability and an ergonomic stand designed with full tilt, swivel, pivot and height adjustments, the ROG SWIFT is ready for long gaming sessions in comfort.
The ROG SWIFT PG278Q represents the next generation in gaming displays. This WQHD 2560 x 1440 monitor delivers four times the resolution of 720p, with 109 pixels per inch or 109 RGB matrices per inch. This gives you the benefits of greater image detail and up to 77% more onscreen desktop space than standard Full HD (1920 x 1080) displays. These minor details add up to give you a major in-game advantage.
Unlock the highest frame rates available, decimate lag and say goodbye to motion blur to gain the upper hand in first person shooters, racers, real-time strategy and sports titles. With twice the frame rate of standard LCDs, the ROG SWIFT PG278Q Gaming Monitor encourages you to never blink again.
Response time and ultra-smooth gameplay are the hallmarks of a true gaming monitor. With a 1ms rapid response time – the fastest available – the ROG SWIFT PG278Q Gaming Monitor eliminates smearing, tearing and motion blur, allowing you to quickly react to your game.
NVIDIA®G-SYNC™ display technology delivers the smoothest, fastest and most breathtaking gaming imaginable. G-SYNC™ synchronizes the ROG SWIFT's refresh rate to the GPU in your GeForce GTX-powered PC, eliminating screen tearing and minimizing display stutter and input lag. Scenes appear instantly, while objects look sharper and more vibrant. Gameplay is fluid and responsive too, ensuring a serious competitive edge.
The ASUS Display R&D team works closely with NVIDIA to ensure that everything runs smoothly on ASUS G-SYNC™ monitors. The ROG SWIFT PG278Q gaming monitor with built-in G-SYNC™ delivers super smooth and stunning visuals.
The ROG SWIFT PG278Q is compatible with the NVIDIA® 3D Vision™ 1 and 2 kits* to support up to three WQHD displays for immersive multi-display 3D gaming experience. ROG SWIFT provides the finest 3D gaming and content viewing experience and thanks to the ever-growing library of over 700 3D Vision™ ready game titles, as well as 3D Blu-ray movies and YouTube 3D Playback support. See everything in a new dimension with the ROG SWIFT.
*Requires NVIDIA® 3D Vision™ kit, sold separately.
Features:-
- Crisp 27-inch, 2560 x 1440 visuals combined with fast 144Hz refresh rate, 1ms response time, made smooth by NVIDIA®G-SYNC™ technology
- Exclusive GamePlus onscreen timer/crosshair, 60-120-144Hz refresh rate turbo key and intuitive 5-way OSD navigation joystick
- Complete ergonomic tilt, swivel, pivot and height adjustment with VESA mount capability for optimal placement
Specification:-
- Fully adjustable stand: tilt/swivel/pivot/height
- Screen Size: 27" (68.47cm)
- Pixel Pitch: 0.233mm
- Resolution: 2560x1440 WQHD
- 2D mode: 2560x1440 (up to 144Hz)
- 3D mode: 2560x1440 (up to 120Hz)
- 2D Surround: 7680x1440 (up to 144Hz)
- 3D Surround: 7680x1440 (up to 120Hz)
- Panel: TN
- Response Time: 1ms
- Refresh Rate: 144Hz
- Brightness: 350cd/m
- Contrast ratio: 1000:1
- Colour: 16.7M (Real 8-Bit)
- Connectivity: 1x DisplayPort (Display Cable and USB cables included)
- USB 3.0 Hub
- 3D Vision 2.0 Enabled
- G-Sync Enabled
- ULMB Enabled (NVIDIA Ultra Low Motion Blur Technology)
- Phys. Dimension with Stand(WxHxD): 619.77x362.96x237.9mm
- Box Dimension (WxHxD): 756x456x300mm
- Weight 7.5kg
- Full Specification: http://www.asus.com/Monitors/ROG_SWIFT_PG278Q/
- Warranty: 3yr (28 Day OcUK DOA, Asus After)
- OcUK Exclusive Service: Warranty regarding dead pixels falls under ISO rules and as such dead pixels if very few are not an actual fault. But at OcUK we value our customers especially when spending such a large amount of money on what is a flagship gaming monitor. As such even if you only have 1 dead/stuck pixel and it has not gone after 3 days, we will class the monitor as faulty and exchange it for you at no cost to you. This service is exclusive at OcUK for Asus ROG Swift ONLY or other qualifying monitors! (Valid for 28 days from purchase)!
Was [£689.99] Inc. VAT
Only £629.99 inc VAT.
ORDER NOW
BenQ GW2760HS 27" Widescreen LED Flicker-FREE Slim Bezel Monitor - Black @ £149.99 inc VAT
Built to bring you the ultimate personal visual entertainment, the BenQ GW2760HS is certainly one of a kind! Featuring the slim bezel, flicker-free backlight, speakers, 3000:1 native contrast, 20M:1 dynamic contrast ratio, and true 8-bit panel performance with deep blacks and minimized light leakage, this VA LED monitor refreshes your view with truly fantastic colors and details. And, its HDMI connectivity leads the path to a whole new level of multimedia enjoyment.
Exceptionally built to please your eyes with fantastic colors and details from every viewing angle, as well as a beautiful slim design, the all-new GW2760HS Full HD VA LED monitor is everything you’ll need for essential home and office use and more! Get ready to enjoy luxury premium visual enjoyment everyday with BenQ!
A stunning work of art, the GW2760HS is fashioned with a slim bezel and slim chassis to create a simple, compact look that complements every contemporary home and office. A slim bezel design not only saves space but also enables a nearly seamless view in multi-display configurations.
The GW2760HS is upgraded to eliminate flickering at all brightness levels. Test Your Computer Monitor for Flickering:
The GW2760HS comes with an ultra-high native contrast ratio of 3000:1 and dynamic contrast ratio of 20M:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games.
Enjoy perfect skin tone and image color presentation from a wide-viewing angle of 178°/178°! The all new Color Shift-free Technology reduces the visibility of color washout, or color shift, between normal and oblique viewing angles, giving you consistent color uniformity and true color definition from left, right, above and below.
Specification:-
- Screen Size: 27"W, VA LED
- Resolution (max.): 1920 x 1080
- Pixel Pitch: 0.311 mm
- Brightness: 300 cd/m2
- Contrast Ratio: 3000:1
- DCR: 20M:1
- Response Time: 4 ms GTG
- Display Area: 476.64 x 268.11 mm
- Display Color: 16.7 million
- Viewing Angle (L/R;U/D) (CR>=10): 178 / 178
- Terminals: D-sub / DVI-D / HDMI / Headphone jack / Line in
- Flicker FREE technology
- VA LED Technology
- Senseye® Human Vision Technology (plus Senseye 3)
- Advanced Motion Accelerator (AMA)
- HDCP Support
- Speaker: 1W x2
- Dimensions(HxWxD mm): 472 x 623 x 191
- VESA Wall Mounting (mm): 100 x 100 mm
- Warranty: 2yr
- Review: http://www.trustedreviews.com/benq-gw2760hs_Monitor_review
- Review: http://www.tftcentral.co.uk/reviews/benq_gw2760hs.htm
Was [£179.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Three very premium monitors at great prices! :)
The asus monitor seems to keep changing price from £690 to £630 and vice versa every week or so not really a deal in my eyes. Although I do plan on getting one very soon
Damn that LG is dreamy! Going to be thinking about that all night now!
Would a gtx 970 cope ok gaming on that beast or would I need to go sli?
when the LG Flatron 34UC97-P 34" WideScreen Super-Wide Curved LED Monitor gets released and comes down in price all be all over that one :D
It has already being released, we shipped 100 units last week, they flew of the shelfs crazy fast. :)
It has already being released, we shipped 100 units last week, they flew off the shelves crazy fast. :)
I'm sure if LG had fitted 'em with VESA mounting holes and a height adjustable stand you'd have sold a few more. Seems utterly mad that they opted for a plastic blanking panel for the back instead on such a pricey monitor.
3 of these together though just look fabulous... :D
A repeat of my above question:
If I had two of these BenQs with my current BenQ XL2411T Rev2.0 24" 144Hz, for Eyefinity would that 144Hz be reduced down to the 60Hz of these two?
