Mini Cooper S Works advice required
14 Apr 2006
Hi all
I'm going to look at a new shape Mini Cooper S Works tomorrow, and I'm after some advice from all the Mini experts.
Do they have any issues I should be keeping an eye out for?
Given that everything seems to be an optional extra which are the most desirable?
Any help is much appreciated.
Johnny
Is it a Cooper S with JCW Tuning Kit or is it a factory JCW? Reason I ask is that a friend had his Cooper S dyno'd before and after the Tuning Kit was fitted and showed only a tiny difference in both torque and BHP.
Make sure it's got Chili pack. Leather is also good. Sat nav is rubbish but looks so cool :(
Not too much to look out for with the R56. They all rattle a bit in the cold mornings (still waiting for a fix for this) and another common prob is the leccy windows not going up properly which is solved with a software update.
Mine has been pretty much spot on.
