- 10 Oct 2006
Ohhhh, expensive fix? His DMF is going too!! Not good.![]()
The turbo is straight forward to remove as it is easily accessed at the front of the engine but you would really need to get the fault codes read to see what the fault is. If it is the 150bhp 1.9 CDTi this also has swirl flaps in the intake manifold which if faulty can also cause limp mode but it generally puts on the engine management light.
