MobilePhone Headphones ?
21 Jun 2005
UK
Anyone can tell me which Mobile phones (if any) support the normal headphone Pin thingy found on most headphones/earphones. :P, instead of some weird phone connection. (forgoten the name of the connector :/)
Or if non currently do, any that will support it?
Maybe the w810i, as its designed for music aswel ?
Thanks for any help guys,
Chadd
Thw w810i has the silyl one that plugs in but on the other end is a normal jack socket so you can put your usual earphones from an ipod or such on it :)
The only phone I know with an actual 3.5mm socket is the Nokia N91.
Quite a few phones these days come with an adaptor though.
My m600 comes with a 2.5mm jack, most headphones are 3.5mm so went looking for an adapter I ended paying £5 for a crappy one in a local shop & its turned out to be as crap as it looks. Struggling to find a decent one online so if anyone has any recommendations??
