1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
MODZERO JUICE - NFC SYSTEMS S4 MINI #80
Discussion in 'Project Logs' started by HackJoe, Dec 15, 2016.
  1. HackJoe
    Gangster
    Sure, providing they make some the same size?
    J.
  2. HackJoe
    Gangster
    [​IMG]
    UPDATE 6.1
    Hi, Things have been quiet on the build front for some time now. I've been crazy busy. I'm now a married man and 8 weeks away from welcoming my first child into this world. I've continued to use JUICE as my daily driver and boy does it continue to impress. A couple months back I uploaded a quick snap showing a quick side panel mod I'd done in time for Insomnia 61 gaming festival. Having the side panel fitted makes the chassis as a whole much more stable.
    [​IMG]
    LAN was awesome (it always is), providing 5 days of freedom from the rest of daily life stresses. Shortly after I came back, I received a message from a dude called Victor. He'd seen my fabricator had fallen through and kindly offered up his time to help me out (what a guy!).
    I sent him my CAD design for the Matrix Orb display bracket and he's run with it, correcting the mistakes I'd made and bashing out a prototype.
    [​IMG]
    Designed to attach to the 120mm fan mount on the S4 mini, Victor has opted to laser cut the design from acrylic. Then mill out where required and tap the holes.
    [​IMG]
    First attempt cut and ready for the mill.
    Victor lives in the US and operates OPEN BOX STUDIOS I recommend you get in touch with him if you're looking for some design/fabrication work to be carried out.
    I'll be back with another update once the parts arrive.
    J.​
Share This Page
