Have bought a cheap mk2 mondeo to last me a month or two after my escort clutch went. Its a W-Reg 2litre ghia in blue, the exterior is a bit battle scarred (scratches, small cracks on back bumber, no rust though!) but it was only £850.
The only problem i have is that on the fuel cap cover the clip has broken so its currently stuck closed with blue tack, it seems like i can remove this from inside the boot but can't work out how, i was wondering if you knew after braking up your mondeo recently?
edit, to be clear the bit thats borken is the plastic that pulls back with the handle by the drivers feet.
