** MONEY!!!!!!!!!!!!! CLASSY ON ITS WAY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
They are starting to ship, expected as early as next week possibly:
EVGA GeForce GTX 980 Classified ACX 2.0 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-2988-KR) @ £579.95 inc VAT
The new EVGA GeForce GTX 980 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. For the first time, gaming GPU's can dynamically render indirect light using the new VXGI (Voxel Global Illumination technology). Scenes are significantly more lifelike as light interacts more realistically in the game environment.
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Features:-
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 980
- GPU: GeForce GTX 980 (GM204)
- Core Base Clock: 1279MHz
- Core Boost Clock: 1393MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Dimensions: 268.6 x 98.4 x 40 mm
- Power: 2x 8-Pin
- 600W PSU Required
- 178W TDP
- Warranty: 3yr
Only £579.95 inc VAT.
ORDER NOW
BOOOOOOOOOOOOOOOOOOOOOOOOOOOOM!!!
Struggling to see why this is £80 more than this, other than the puny 12MHz base clock increase. :confused:
Previously EVGA only binned the Classys, so they are basically guaranteed clockers while the rest of the line-up were silicon lottery.
I say previously because it looks from the specs that the Hydro Coppers are clocked even higher this gen so they may have binned them too this time around /shrug.
Unless these 980 can hit 1800MHz+ on air, I just don't see the point of spending average of £120 extra over the other 980...
Worth it for the guys buying who do extreme clocking or just want a Classified.
Otherwise just buy the EVGA 980 SC model at sub £500. :)
