Personally, I think it depends on the bike, for example. The k3 650 out of the factory is ment to be running richer than normal, so adding the filter and having an aftermarket can would lean things out a bit, making it a good ratio. However, this doesn't mean every bike will.
K&N say you don't need to alter fuelling or anything what so ever, won't kill the engine etc, and if they say you don't have to that's good enough for me, as if they lied about it surly it wouldn't be legal?
I like the k&n products. You can wash and re oil the filter not throw away. Oil filters come with basically a nut on the end of the filter so you don't have to faff about with adopters to get them off.
I read somewhere the K&N ones, rather than allowing more air, just keep cleaner/clear for longer and are also maintainable/lifelong (million mile warranty).
The only way to stay cleaner for longer is by being a more inefficient filter in terms of catching particles and allowing more air/crap through though which doesn't sound great, also the oil residue can mess with any sensors if they're installed.
Or you know increasing surface area....
By using bigger corrugations and more material you can catch the same amount of cap but provide more unclogged area for air to pass through.
Not saying k&n or any make is better than another but saying that the only way to stay useful for longer is by being more inefficient in terms of catching particles is false
You can wash the stock OEM sponge ones,I washed mine about 5 times in a bath of petrol and re oiled it,it eventually broke down so I replaced it
K&N Increases Performance And Horsepower of 2009-2012 Kawasaki ZX-6R Ninja Sportbike Motorcycles
K&N racing air filters are designed to have just two layers of cotton to provide even less air restriction than the standard K&N replacement street air filters. Fuel management modifications will be necessary with this racing filter, unlike the standard replacement air filters. K&N racing air filters come with a one year limited warranty and are washable, re-usable and are easy to fit.
