I have a wiring issue though: the lights are as expected at low beam, but when I switch to high beam, both lights switch off. The one thing I didn't do was check the configuration of the kit's connection to the wiring loom, stupidly assuming that it was standard and would be the same layout on all kits. So hopefully I just need to move the pins on the H4 plug.
is the colour ok now you've got used to it? or is it still too blue? looks ok to me,think id go for that colour bulb aswell
and yh you want some led white parking light bulbs next,have some good ones on my zx10 (I see you already have em haha)
did the headlight seal backup aswell? I had to put some clear silicon sealer round mine just to be sure
Sagalout said:Yeah, I'm really happy with mine too - makes a huge difference on dip...not so much on full beam. Used all this week and not one person flashed me
How does the dip / full beam even work? Do you just revert to halogen for full beam?
Let's be honest, anti-glare bulbs are an inferior substitute for bi-xenon projectors with solenoids to take care of dipped / full beam. 'Anti-glare' translates to reduced light output once you get past the marketing, you've just joined the ranks of every other muppet that sticks HIDs in a reflector unit as far as I'm concerned.
Each to their own - mine looks more stock than your chavtastic angel eyes![]()
You can't get any less stock looking and any more chavvy than HIDs in reflectors. At least someone somewhere stuck angel eyes (which I can switch off in a second) into a vehicle from factory. Nobody ever stuck HIDs in a reflector from factory, because it's inconsiderate to glare other road users.
So show me your leveling and washers? Your bike is just as 'illegal' as mine, the main difference being you've made yours untourable for you and any future owners with s permanent DIY bodge , whereas mine can be put back to stock within a few minutes.
Not actually true. Some car manufacturers have used HIDs with reflectors, it's quite possible to design a reflector that works correctly with the shape of the HID light source. Projectors are much more compact and cheaper however, so they are more common despite being an inferior solution in terms of light output.
Projectors are cheaper and inferior?
What?
