Mountain Bike peeps, help me choose a (Rockshox) fork.
7 Dec 2002
Kent
Can get either Rcon or Tora Solo for £169.......
Tora U turn for £144.
I am a 13 stone rider and need something reliable for generel XC and "all mountain"
Going on an '03 Marin East Peak which has 100mm rear travel.
I am thinking:
Tora 318 Uturn (£144)
GOOD: Cheap. Coil spring so better for my weight? Upper tubes are steel so better for hard hits/ crashes?
BAD: Weight. Have to change spring if too soft for my weight (is that correct??)
Tora 318 Solo/ poploc (£169)
GOOD: Poploc, air sprung so can adjust for my weight easier.
Bad: Weight. No coil spring so not as reliable?? Do I want/ need poploc?
RECON 327 Solo air (£169)
Good: Weight. Air sprung so able to adjust them easier for my weight.
BAD: Air sprung, so not as reliable?? Ally upper tubes not so good in a crash?? No poploc.
Help!! :)
If you're 13 stone and only doing XC there's no real reason to avoid air sprung shox, I haven't looked at current suspension in ages.
Edit: Coil will be more progressive, I quite like my air shock as its so smooth throughout
I ride a Judy3 SL on my Rockhopper, and it's quite a nice fork. The lockout is excellent, as it activates if you need it in a hurry, e.g. if you hit a rock or a sudden drop-off. I'd recommend that in a second.
Why does it have to be Rockshox, aren't there any other decent forks out there for the money?
EDIT: I ride a hard spring in mine, I'm 12 stone at present and it does me fine.
