Caporegime
Try hearing a XFX cooler at 100%... that's on a completely different level.
Luckily Sapphire coolers are quieter *pats 7950*
I can't believe a XFX cooler is louder at 100% than a reference AMD fan.
Mine is a Xfx not had it hit 100% but at 70% its not so bad. But I use headphones when gaming so not bothered If I do use a higher Fan speed to keep temps down.
Am aiming below 75C for any game think its possible?
.I've not had a reference cooler so I can't comment on it, but my XFX 6850 on 40% was annoying as nuts.
Are they using the double dissipationon on that card?
Worse. Single:
It was a card I won from AMD though, so was a free upgrade from my 5770.
Worse. Single: http://images.bit-tech.net/content_...eon-hd-6850-review/xfx-radeon-hd-6850-2-l.jpg
Ive got SLI 480s and i use a custom profile to control both noise and heat![]()
