MSI RTX 3070 Suprim water block?
15 Jun 2021
London
Hello does anyone know if there's a water block to fit this PCB
There's one that's called Barrow MSI RTX 3070 SUPRIM Water Block but i'm not sure it's going to get the job done because it's a fair bit shorter than the PCB.
Have you measured the PCB on your card? Note that the cooler is longer than the PCB, you can see the rear vent where air is pushed through the heatsink and out the rear (backplate) of the card.
N.B. linking to competitors of Overclockers UK for products which they sell, will get you in trouble. These forums are of course funded by OcUK :)
I had trouble finding one that worked with the aorus 3070 master. Was between byski and barrow as its not really supported by the normal brands.
Pcb is very short compared to the card. Probably 100mm shorter so don't worry about that.
Did you manage to find a suitable waterblock? I know the PCB is identical to the 3070 gaming X Trio, but you have to be careful if looking at the Bykski ones, as even though they say it works on the Suprim it doesn't fit due to the extra VRM
on the Suprim. I have unfortunately made that mistake and I'm now stuck with a waterblock for the gaming x trio that doesn't fit :(.
I'd like to know if the Alphacool waterblock for gaming x trio fits it, but can't find any images that would suggest it does. I'm not a fan of the Barrow one.
Yeah I was looking at the alphacool one but it doesn't say anything about the Suprim... I might go with the Barrow one since it says it fits ...
