Hi there
OcUK has done the best job again, new prices on MSI cards, including the Lightning Deal everyone was asking for.
MSI Radeon R9 290X Lightning Edition 4096MB GDDR5 PCI-Express Graphics Card @ £319.99 inc VAT
The MSI R9 290X Lightning is a genuine contender as a powerful gaming card. Not quantified by "for a Radeon", this thing is fast, full stop. Easy, and rewarding to overclock with a fantastic cooler and every option you could want. It's Brilliant. It's Rapid. It's Yellow. It's a worthy winner of our OC3D Gold Award and the best Radeon card on the market today.
Features:-
- Triple Level Signals: Show the real time GPU load by different colours
- TriFrozr Thermal Design: Triple PWM fans with independent control system on
- Pure Digital PWM Control: Digitally controlled GPU, Memory and VDDC.
- Twin BIOS: Seperated BIOS chips for regular use and LN2 overclocking.
- Enhanced Power: 12 GPU phases and 3 memory phases on a custom designed 12 layers PCB for amazing overclocking potential.
- Military Class 4 Components pass MIL-STD-810G certificatiomn for best stability and quality.
- Equipped with CopperMOS, Hi-C CAPS, New SFC and All Dark Solid CAPs.
- Triple Overvoltage: Total control with GPU, Memory and PLL voltage adjustment.
- Triple Temp Monitor: Real time monitoring of GPU, Memory and PLL Conditions.
- V-Check point: For direct and accurate read-out of GPU, memory and PLL voltage.
Specification:-
- Radeon R9 290X
- GPU: Hawaii XT
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1080MHz
- Memory Speed: 5000Mhz (Samsung IC)
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- PCI-Express X16 lane required
- 750W or greater PSU required
- Power Connectors: 2x 8-pin + 1x 6-pin required
- Warranty: 3yr
- Download PDF Presentation: https://www.dropbox.com/s/9kkxjuw2a0n421v/R9 290X LIGHTNING Infokit 1_0 - PDF Version.pdf
Was [£499.99] Inc. VAT
Only £319.99 inc VAT.
ORDER NOW
MSI Radeon R9 290X Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £269.99 inc VAT
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:-
- Radeon R9 290X
- Backplate included: Yes
- GPU: Hawaii XT
- Litecoin Hash Rate: 850-1000
- ROPS: 64
- Core Speed: 1040MHz
- Cooling: MSI Twin FrozR Gaming Cooling
- 600W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 3yr
Was [£329.99] Inc. VAT
Only £269.99 inc VAT.
ORDER NOW
MSI Radeon R9 290 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £215.99 inc VAT
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- Radeon R9 290
- GPU: Hawaii Pro
- Litecoin Hash Rate: 800-950
- Stream Processors: 2560
- Core Speed: 977MHz
- Warranty: 3yr
Was [£259.99] Inc. VAT
Only £215.99 inc VAT.
ORDER NOW
Great prices from MSI!!!!
Features:-
Specification:-
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 3yr
ORDER NOW
Specification:-
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 3yr
ORDER NOW
Specification:
- Radeon R9 290
- GPU: Hawaii Pro
- Warranty: 3yr
ORDER NOW
