msi z68a-gd80 6-pin + 8-pin connectors?
7 May 2011
I'm still speccing up my new build, and have never used an 1155 mobo, so need to know what cables / extenders I need.
Does the above need both 8 and 6pin power connectors?
It the standard connector on these mobos 8-pin?
Sorry, coming from an AMD skt 939 mobo...
Blonkster
You would need the 8 pin for CPU power and the main 24 pin ATX connector.
Edit: I would suspect the 6 pin would be used for running multiple gpu's.
Dependant on what gpu you buy this will would need the 8 pin and 6 pin or 2 x 6 pin.
