MX1000 middle click starting to die?
21 May 2003
Has anyone else experienced the middle click seemingly not responding unless pressed really hard? I've had my MX1000 for about 2 years but recently this has started happening.
Am I right in thinking this mouse is covered by a 3 year warranty? Do I just ring Logitech, and if so, whats the contact number please?
27 Nov 2002
Catford
When i 1st got my mx1000 the middle click was not working properly, rang them up and they send me a replacement, same problem, i just gave up and determined its a badly built mouse :)
2 Oct 2006
google + 30seconds of time = you could find the answer yourself maybe?
well ok i saved you the trouble, you do have a 3yr manufacturers warranty on an mx1000
heres logi's number
Hot line: +44 (0)207 309 01 26 (technical support and warrantee handling)
OP
21 May 2003
Cheers, much appreciated.
I was assuming someone might have had previous experience with getting a replacement MX1000 and might have had a suggestion or two on the best way to go about it, hence the lazyness :)
Vai
Vai
18 Oct 2002
I had this problem, didn't think it would be under warranty though. Was simple to fix, just open it up and put some electrical tape over the piece of plastic that hits the button when you click. Works good as new now :p
