Deleted member 651465
D
Guys,
I've had a bit of a crap 18 months with health issues etc so I'm looking to build a new machine for the first time in over 7 years as a treat to myself and as an investment.
The nature of the system will see it being used for professional wedding photography, audio recording (semi-pro - although that may change) general office work and a spot of gaming. I don't plan on upgrading the system for a while (my last one is rocking a 3930k and 680) so I've gone for something with specs above what I need now on the basis the raw horsepower will last me another few years.
I've already got a case (Lian Li Dynamic XL), keyboard and mouse and have a 40TB NAS Synology for work. I also have reference headphones and was considering ditching the speakers altogether.
This is my first time considering ultra wide and I like the look of the LG and the colour accuracy of the IPS panel, although I understand the brightness/HDR isn't first in class. I'd consider multiple monitors if I had to but prefer the lack of bezels with a single large screen.
I've also never done hard tubing before, so I've completely omitted that although I will need to spec it at a later date.
My basket at Overclockers UK:
- 1 x EVGA GeForce RTX 2080 Ti FTW3 Ultra Gaming 11264MB GDDR6 PCI-Express Graphics Card= £1,328.99
- 1 x Asus ROG Strix TRX40-E Gaming (Socket sTRX4) ATX Motherboard= £469.99
- 1 x AMD Ryzen Threadripper 32-Core / 64-Threads 3970X 4.50GHz (Socket TRX4) Processor - Retail= £1,769.99
- 1 x Corsair AX1000 Titanium 80 Plus Titanium Power Supply (CP-9020152-UK)= £219.95
- 1 x Team Group Xtreem "8Pack Edition" 64GB (4x16GB) DDR4 PC4-28800C17 3600MHz Quad Channel Kit - Black= £499.99
- 1 x Seagate Firecuda 520 2TB PCIe 4.0 NVMe M.2 Solid State Drive (ZP2000GM3A002)= £374.99
- 3 x EK Water Blocks EK-CoolStream PE 360 (Triple Fan) Radiator= £77.99
- 1 x Corsair Commander PRO RGB LED Controller + Fan Hub - Black= £64.99
- 3 x Corsair LL120 RGB, 120mm Dual Light Loop RGB LED PWM Fan, 3 Fan Pack with Lighting Node PRO= £92.99
- 1 x EK Water Blocks EK-DBAY D5 PWM (incl. pump)= £134.99
- 1 x EK Water Blocks EK-Velocity sTR4 D-RGB Threadripper CPU Water Block - Nickel + Plexi= £94.99
- 1 x EK Water Blocks EK-Vector EVGA FTW3 RTX 2080 Ti Backplate - Black= £34.99
- 1 x EK Water Blocks EK-FC GeForce RTX 2080Ti EVGA FTW3 Graphics Card Water Block - Nickel + Plexi= £139.99
- 1 x Thermal Grizzly Hydronaut High Performance Thermal Paste - 26 grams 10 ml= £23.99
- 1 x LG 38GL950 38" 3840x1600 NANO IPS 144Hz G-Sync HDR Widescreen LED Backlit Curved Monitor= £1,798.99
- 1 x Lian-Li PC-O11DXL-1 Riser Cable + PCI-E Bracket Kit for PC-O11D ROG Series= £49.99
- 1 x Wavemaster CUBE NEO - 2.0 Bluetooth Bookshelf Speaker System - White= £199.99
Total: £7,719.75 (includes shipping: £0.00)
