My new engine - Its says V-Spec on it!
18 Oct 2002
Pembrokeshire
With the recent threads on all the new stuff folk have received through the post, I thought I'd show you my latest purchase.
O.S. .21 (3.5cc) VZ-B V-Spec
Max RPM 40,000
Max 2.5HP @ 33,000
Will be run on 25% nitro fuel.
If you've never heard these engines check out youtube. They sound awesome. Get half a dozen cars at the startline and you can't hear a bloomin thing :D
you rebuilt one yet? they're so cool, i had a nitro car when i was 15 and yeh they do sound awesome
Its to go in this:-
Kyosho Inferno MP777 SP2. Upgraded brake discs, chassis brace, TCD front diff (bit like limited slip)
Summer season starts 31st march. Been out the scene for 2 years and can't wait to get out there.
Make sure you get the OS 2050 pipe to go with it.
I run a V-Spec with above pipe best combo by far, they are a tad dear though.
my V-spec is also in a Kyosho but a K3 not a triple 7.
Also have a lightning 2 pro with a rossi P5 which I prefer and a full alloy T-Maxx with an RB323.
looks like I also like my RC buggies.
I was going to get a Jammin JP4 to go with it.
However, I've got my eye on an XB8EC with a RB C6. Not sure on pipe but has spektrum digital servos.
The Xray is pretty much new and is ready to go bar TX and RX which I've got (KO Type R)
I only bought the 777 as I've had one before and it was great with an older OS engine it was very reliable. Only ever gave trouble after bumping 2 finals which meant running near enough flat out for half hour before it conked out in the third. :)
