- 25 Mar 2006
- Thornbury
i use newsleecher to download and my max speed is 320 kB/s (2.5mb), so im assuming this figure is reliable and not far away from the results of 'my broadband' speed test. Not so long ago i got 380 kB/s using newsleecher so my speed is down.
I called sky about this, i have done what they suggested -
reset router
tried master socket
replaced microfilter with new one
tried network cable from pc to router
Nothing makes any difference. The guy at sky told me to check my DownStream Connection Speed (which is 3069) on my router setup page. He said i should then get 3mb. He says as my modem is showing this downstream speed thats what is it recieving so he is saying i am losing some of the speed at my end and he said it might be my wireless connection however i have proven its nothing to do with it as i get the same speed with wired.
is there anything i can do or check or do i have to keep pestering sky again?
cheers
reset router
tried master socket
cheers
