N00b needs help overclocking Biostar Tpower X58
23 Feb 2009
Hi guys!
I managed to get my i7 920 to 4.3GHz (215x20), but it was just stable for 9 hours in Prime95 with small FFTs.
Load temps with my watercooling:
1: 76-77c
2: 76-77c
3: 76-77c
4: 73c
What should i tweak next? Im kinda a nub so i dont really know what to change and when to change it.
CPU + 0.240 gives 1.38 volts
VTT 1.38 gives 1.344 volts
PLL Auto
Dram 1.66 gives 1.648 volts
NB Auto
SB Auto
QPI 1.25
If your stable with those volts i really would just leave it alone now tweaking for the sake tweaaking will end in tears and headace...enjoy your rig now.
Ah you didt say it failed...anway you can chase stabilty all year long is 6,8,12, 24 hours when is enough enough? I am very happy with a 8 hour prime stable rig...maybe do some linx 20 passes or so...then do a day of gaming it passes those i would consider is stable regardless if fails a 9 hour prime etc
