- 14 Dec 2009
Gone way above my original budget here. Somone told me trying to stick to a intended budget is an art, as you will alway want more in most departments. Well, for me, it was the graphics.
Anyway, before I buy, I just need some reassurance that the build I've chosen will all be compatible and work well. Also, I need a recommendation on 4GB DDR3 memory which won't break the bank.
Thanks in advance.
Already have AMD Phenom II x3 720 CPU
Thanks in advance.
