- 6 May 2009
Right,
This is really doing my head in.
My Xbox won't connect to LIVE no matter what...
I've tried enabling UPNP, that does not work... I've tried forwarding the required ports... That does not work...
I have tried assigning a static IP address and then fathing around with the LAN setup options... That did not work...
I'm at my wits end here. I really need help!
An odd thing to note is that sometimes, I will disable UPNP, wait for it to update then re-enable it. Then turn my console off then on and it will connect. Very odd.
My router is a Netgear WGR614V9
