Quick question, I chose just the default "Synology Hybrid RAID (SHR)". Will that give me redundancy to the second HDD?
Synology Hybrid RAID is only normally used when RAIDing disks with different capacities. Just do custom and then select RAID1 for redundancy (assuming 2 disks).
Oh right, well saying as I've now it now, will I still have redundancy yeah? That's all I'm worried about. I've copied data across now so I'd hate to have to start again...![]()
When you select SHR does it give you an option to pick which RAID type you want? If RAID1 is there then you should use that.
Synology said:The SHR is designed to meet the needs for those users who do not care or do not want to know what are the finer aspects of the various RAID-levels which are currently supported on the DiskStation, and would like to use the SHR to handle RAID management, storage expansion and maximize storage capability. The SHR allows for 1-disk worth of redundancy - meaning that the SHR volume can suffer the lost of one disk, and the data volume will still be available for use.
So does your volume only have half the capacity of both your disks combined?
Sounds about right - enjoy it!
But, I'll take a look at that later.
Just got to sort out a niggling problem, when I turn my PC on, Windows does not re-connect the mapped drives.But, I'll take a look at that later.
Thanks all.
I have the same issue, not sure if there's a fix.
When you mapped the drive did you tick the box saying 'reconnect at login'?
If you click on the drive with red cross does it not then spin up the device and let you browse files?
Sometimes I see red cross but when I click drive it is fine.
