**too long dont want to read? what's your default colour profile for windows and colour settings in photoshop?**
became familiar with colour profiles in windows when i was fed up with how bad images looked in Windows Preview. after i saw some other ppl posts the same issue i looked into it and saw that it was worth setting the default profile in windows to sRGB. yay all good.
(also had issues with Photoshop colour before also, where the image looked different in PS than in windows or on the web).
now a few months ago the colours seemed bad again (hadn't changed anything) and noticed the profile had changed to [24 inch lcd for pc] hmm ok so i checked for sRGB again and there is more than one but picked one that looked most likely but it's name is [sRGB IEC61966-2.1] which is different that i remembered but that seemed to work ok.
again i havent changed anything and was importing pictures from my CF card 2 days ago and they seemed dull/desaturated especially after seeing them on my parent's pc. checking all other images from Bridge and they were all messed up aswell.
changed photoshop default colours to Adobe RGB 1998, that sorted that out but also changed windows colour to Adobe RGB 1998 to match
things were looking great until i was saving for web, in the JPEG option there is a box [convert to sRGB] which makes things very saturated / vibrant which would tie into the sRGB problems someway. but i don;t know what it will look like on other ppl's computers.
anyway i'm getting all confused with it so if you could share your windows and photoshop colour profile names then i'll try some options.
thanks
/edit, using vista x64
thanks
