Hiya!
Id really appreciate any help you can give me. I have read many stickys/guides etc on how to overclock an i7 to 4Ghz but i am still cant get my head around it. I have overclocked an AM3 before (955 from 3.2 to 3.8) and thought i could do the same with an i7..but apparently not.
This is my spec
CPU: i7 950 (h50 cpu cooler)
Mobo: p6x58d-e
RAM: OCZ 4Gb 1333Mhz Gold (duel channel)
GPU: 5870
PSU: XFX 850W
What ever i do i just get BSOD after about 15mins of prime95. I have tried many combinations 175BCLK*23 200*20 etc and nothing seems to work. I have even upped the CPU voltage to 1.35 but nothing seems to work. Where i am a bit hazy in my OC knowledge is the way the ram overclock with the cpu. My ram runs at 1333 (stock) so should i be aiming to keep it at 1333 (or as near as possible)
At the moment it can end up around 16000 or even higher. Also the amount of settings you can change. Pll, QPI etc It just goes over my head a little.
I have even tried some ‘template’ settings but I’m not sure what to twiddle with tbh to get it to work. I have seen SO many on these boards say how easy it was to get to 4Ghz without ever trying. Is there something wrong with the chip or board? ><
Seriously can anyone give ANY advice.
Also as a side note the stock temps dont seem much lower than overclocked temps.. is that a good or bad sign?
P.s i wasn’t joking about the WoW gold lol if you help me get a stable 4Ghz 10,000G is yours on hellscream server
..or 3,000G on eonar.
scroll down for bio pics
ty for your help
This is my spec
Mobo: p6x58d-e
GPU: 5870
PSU: XFX 850W
..or 3,000G on eonar.scroll down for bio pics
ty for your help
bit diff from a i7. thank you tho
ill let u know back tonight/tomorrow of how tho settings went
