Fap stains? or snail trails.
never masturbated in my life, and dont plan too for the matter.
You little liar!
Please tell me that you were joking about using bleach!!
These lines are from the washing powder. This often happens if the washing machine is overloaded so that the rinse cycle is not as effective as it should be. The best solution (pardon the pun) is to use a damp cloth on the lines and that should wash them off.
im 15....and im Muslim so im not one of those little porn addicts you guys think of.
Protein stains. Put a drop of bleach onto a cloth and rub until the stain is removed.
If you don't masturbate, you will eventually explode.
