Need jumper numbers for very old TMC T15VG+
29 Dec 2005
I have a very old t15vg+ rev 1.00 i think its made by TMC. I cant seem to find the manual but I was thinking of setting it up as a server for my home network but I cant get it to start up as I cant connect the power and reset switches etc.
Can anyone give me the connections numbers for power and reset switches and the power and hdd leds? I know its J13 on the mobo but there are 20 pins and no clues given on the mobo.
Please help me out. I cant find any info on the net at all. Probably because its a 7 year old model but would have thought there would be something on it.
Cheers
Paul
I've got one of these. Used to run a K6-III on it back in the day... Think TMC are now out of business but it was a decent motherboard at the time. I'll see if I can find the manual.
That would be great if you could Ive been hunting for a while for mine and I cant find it anywhere. Im sure I put it somewhere safe so I would be able to find it again.
Those links were quite good aswell thanks it does most of the buttons but not the power switch.
I think Ive found the power pins. Trouble is when I put the power on then press the power button the fans do a couple of revs and then stop then if i press the power button after that... nothing.
Either theres a short somewhere which I cant find or its a dead mobo/processor. Looks like Ill be spending money to get this working then.
Thats great thanks. Now I need to figure out if its a dead motherboard or a short that I cant see. I thought it was gonna be nice and easy to just whack in a hard disk and it would work but things are never that simple. Cheers for finding that manual.
