Need new fans for Athlon 2400+ machine
21 Aug 2005
The fan lead to change temps on the CPU cooler has broke, so I need a replacement. Would any 754 one do the trick? Was looking at this one. Itll be replacing an Coolermaster Aero 7.
Arctic Cooling Alpine 64 CPU Cooler (Socket 754/939/940) (HS-020-AR)
Also need a new fan for the 9800 pro as one of the fins off the stock fan has broke. Can someone recommmend oen thats easy to install.
Thanks.
You are looking for socket A one, like this:
Zalman CNPS7000B-ALCU Ultra-Quiet CPU Cooler - Retail (HS-008-ZA)
Price: £14.95 (£17.57 Including VAT at 17.5%)
Be carefull though as the one mentioned needs 4 mounting holes around the socket as it doesn't use the standard clips so a lot of motherboards wont be compatable.
best bet for the socket A is a thermal take big typhoon but again it requires mounting holes. second best option for socket A is the gigabyte g-power cooler.
Right I'll get the Zalman. Is the
Arctic Cooling ATI 1 Rev.2 (9700/9800 Series) VGA Silencer (HS-002-AR)
decent?
