Need some case/fans/fan controller advice for new build
18 Oct 2002
Finally back home in Cork, Ireland.
Just about to dive back into building systems after a long lay off and things have moved on since I last did any major work.
I pretty much think the case is going to be an Antec 900-2 or 1200 (still dithering so if someone can supply firm advice either way, it would be a godsend)
Are the fans that Antec supply in the cases ok? If so, can you also suggest a decent multi channel fan controller?
cheers.
Scythe Kaze-Master 5.25" Fan Controller - Black
Same here, but have 1200 RPM Slip Stream fans, also from Scythe. Quite happy with the set up. The controls on the Kaze Master are a bit sensitive, but the fans will happily operate at ~650 RPM, with decent airflow.
