I haven't overclocked a core 2 quad before so some of the mobo features in the bios are a bit different to my i7 system, which im used to. Any ideas what sort of settings/volts i need to be using for say a 3.4GHz overclock roughly? So then i can start tweaking them. By the way the q9550 is an E0 stepping.
So far i've worked it out to:
Multi: 8.5
FSB: 400mhz
DRAM frequency: 800mhz (Memory: 4GB Corsair XMS3 DHX 1600MHz)
DRAM timings: 9,9,9,24
PCIe freq:100
cpu vcore:about 1.25v
cpu GTL & PLL voltage: im unsure wheres best to start setting these to
nb voltage: what do you recommend here? I would have thought stock, but im not sure what that is.
Load line calibration: probably disable for starters
DRAM voltage: 1.80v
CPU & PCIe spread spectrums: disabled
Power saving features i'll disable and re-enable afterwards
Multi: 8.5
FSB: 400mhz
PCIe freq:100
DRAM voltage: 1.80v
