Also how much will I need...on minimum mark!
Doesn't the manual / handbook tell you what spec' the oild should be?
[TW]Fox;22594209 said:Halfords own brand? Really?
[TW]Fox;22594209 said:You need to use proper VAG Longlife approved oil, not unapproved oil which simply claims to maybe meet the specs. Halfords own brand? Really?
It either meets the specs or it doesn't. Halfords own branded oil is not the kind of floorsweepings you get from the pound shop, it's decent quality oil.
Indeed, read some very good reviews for it.
floorsweepings from the pound shop
'Meets requirements of' and 'approved 'are very different hinge
Do VW, Mercedes and BMW etc all charge to have an oil approved? Or do you just submit and they will approve it once they have tested it?
